Edcor OPT's multiple taps
Moonwatcher
Hello, all,
I have Edcor ouput transformers, model CXPP25-8K (I think), on a Maggie 9300 series amp. Does anyone know if it is possible, or possibly harmful, to use both the 4 ohm and 8 ohm taps simultaneously on two sets of speakers? I'm hoping to get the strong and velvety mids from early Wharfedales (8 ohms, sort of) and the deep bass from a pair of Smaller Advents (4, sort of). Thanks!
No, I am afraid it is an “either-or” situation. You can certainly compare one and then the other but they cannot safely be run together.
Those must be big transformers if 25W.
If the speakers were 8 and 16 ohms- then, you could put the 8 ohm speakers on the 4 ohm taps, and the 16 ohm speakers on the 8 ohm taps, and each would get half-power- the amp would still see the correct total load.
However- no, there is no way to do that with a 4 ohm and an 8 ohm speaker, unless the amp had a 2 ohm and a 4 ohm tap.
Regards,
Gordon.
I see, Gordon, thanks. Is there any way I could wire resistors in series with the speakers to make it work? Say 4 ohms in series with the 4 ohm speaker and 8 in series with the 8 ohm speaker?
Resistors would waste half the amp power, and probably cause the bass to be boomy and uncontrolled, due to the lack of damping factor.
Regards,
Gordon.
OK, thanks. I've also tried just running the Wharfedales on the Maggie and the Smaller Advents on the Marantz 2230, and it's quite lush--if maybe not quite as dimensional. Co-amping with solid state and tubes is pretty unconventional, I guess.
