Lazy!!!! You know how heavy is that stupid thing?!!!Look for parasidic supersonic oscillation at the output with O'scope, compare both channels.
Maybe it's easier to roll the scope out. Still very lazy to do that as it's going to be replaced soon.
Dunno myself, solid state amp design is waaay above my pay grade.I am just thinking out loud here.
My 10ft 12 gauge monster gave 0.14% THD at 20KHz as the thread starter here. Then I did parallel 3 section of the 3ft 12 gauge Monster cable and pretty much reduced the THD by half. I can't find the specific post on the number. But if we follow this trend, If I parallel 4, I should get about 0.14%/4= 0.035% for 10ft. So it should be comparable to my 10 pairs of 20 gauge red/black wires twisted together.
I measured the capacitance of that cable, it is about 240pF. So 4 pairs in parallel will give me about 1000pF. The 10 pairs of re/black 20 gauge measured 2200pF. This means if I use 4 pairs of 12 gauge monster, I should get the same THD but HALF the capacitance!!!!
I am thinking about ordering some 16 gauge red/back speaker wires. put say 6 pairs and twist together, I should get the cross sectional area of almost 8 gauge and still have capacitance of about 1500pF. I should get THD down to about 0.03% or lower at 20KHz.
What do you guys think.
I was actually looking at some CAT-5 cables per your suggestion. They are all 24 gauge. No wonder the capacitance of yours is so high. You must be using like 15+ pairs in parallel together.Fwiw, I dug out the cat 5 office phone trunk cabling I mentioned previously and measured length and capacitance. They are ca 15ft each and measured ca 6477 and 6560 pF on an AAD LC meter. Cap loss showed 1% on another device.
View attachment 913753 View attachment 913754
Do you have the "standard" series combination of 0.1 uF and 10 ohms from output to ground? With my Tiger amps and their admittedly wonky output stage with gain, I could never get stability without the carefully selected output inductor. It was larger than most recommend, I remember something like 10 or more uH. PMing you something. Yes, vacation was really great. Haven't taken one in a long time.
I use LTSpice to do the bode plot, it is not accurate at all. It is to the point it's useless. I wasted so much time on LTSpice before, neither the bode plot stability and THD is useful at all.Time for a Bode plot on the amp?
