EICO 377 Help!
kennymutzy
I got this audio signal generator for free. It works but not completely. Seems like once it gets up to/past 40K/4K etc. it comes on i have signal and can hear sound on speaker. From 40 all the way up to 200k/20K Etc. But as soon as dial gets to 40K/4K Etc. Nothing!
Even on Oscilloscope i can generate a sine wave from 40K/4K Etc. up. But from 40K/4K down not a thing. If I can get any insight or help would appreciate it. I also want to note I went through the calibration via just using a meter. Manual states that it sopposed to be between 10 and 11 volts I have it at about 10.60v. I had to turn the R9 pot up a tad because it was in the low 9’s. Then it said to turn dial back down to the 20K/2K and test again and the voltage should be the same all the way throughout. Well it’s only reading about .440” Thanks for any and all input, advice, or help.
Welcome to AK. It's been pretty near a half century since I've looked inside an original Eico 377, so please take anything I say with a grain of salt. Might happen that some others with fresher experience will come along. I see there are also some possibilities in the "Similar threads" listing below.
But I'll start with the "easy" stuff. It almost looks like your unit is all original - any idea if that is so? Even if not, I think the electrolytic capacitors should be the main suspects - both the power supply filter "can", and the axial-leaded electrolytic caps (identifiable by having a "+" marking).
To be honest, unless this will be a labor of love, you might be better off using a phone app or something as a generator. It might take quite a bit of work to get the Eico working reliably.
