54321James
I am a true novice tube tester. I just purchased an Eico 625 tester. The manual says "Adjust LINE ADJUST potentiometer until meter reads within a division of "Line." This is a little vague to me. The meter shows a red area (labeled REPLACE), a yellow area (labeled WEAK with "Line" above it), and a green area (labeled GOOD). Do I adjust the LINE ADJUST pot so that the dial touches the dark line between 400 and 600 under the LINE in the center of the WEAK yellow area? Do I return the line adjust pot to the suggested selector setting BEFORE pushing the merit button, or do I leave it in the line adjust position and then press it? I am very confused...
