The 667 isn't a bad tester, but you should be aware that the roll charts may not be up to date. There is a more current version on BAMA (google it) that should be checked first if the one in your machine isn't the current revision. I've not had any trouble from my 667, but I did replace the cap and the rectifier when I got it, and did whatever the calibration process was. I forget specifics but it was really simple. One other trick I've learned is that you want to set the line voltage with a tube plugged in, and if you're doing multiple different tube type, check it periodically to make sure it hasn't drifted. The voltage scale on the dial is pretty much worthless too, so don't go by it.
