Hi new guy and fairly new to all of this Tube amp stuff.. Just a hobbiest with a background in auto repair and basic electricity. One thing I have found very helpful is to ask the google AI and talk with it. It has access to all the manuals and schematics as well as all the internet forums. Be specific with it.. it can tell you how to do the voltage checks. I started by wondering if you need a new can cap since that would be the first thing I would replace. I looked up the schematic and it has 2 can caps.. I thought maybe that is left and right so I asked google.. nope not left and right. The following is the conv I had, hope something here helps.. take it with a coupld shakes of salt, it is worng a lot of times.. but still helpfu.
Google AI output:
AI Mode Conversation: hey google what are the role or C19 and C20 in the eico 2050 amplifier .. these are the 2 can cap.. is one for left and one for right channel?
You said: hey google what are the role or C19 and C20 in the eico 2050 amplifier .. these are the 2 can cap.. is one for left and one for right channel?
No, they are not split by left and right channels.
In the vintage
Eico 2050 tube amplifier, the two multi-section twist-lock can capacitors,
C19 and C20, are shared by both channels. They function as the core components of a single, unified
power supply filtering and distribution network. [
1,
2,
3]
The Roles of C19 and C20
Instead of separating the audio channels, these caps are arranged sequentially to smooth out high-voltage alternating current (AC) ripple into clean direct current (DC) for different operational stages of the amplifier:
- C19 (Main Reservoir Filter): This multi-section can connects directly to pin 8 of the V11 rectifier tube. It handles the heaviest lifting by taking the raw, pulsing DC straight out of the rectifier and smoothing out the primary AC hum. It provides the main high-voltage B+ rail that feeds the plates of the four 7591 output power tubes (V7, V8, V9, and V10). [1, 2]
- C20 (Downstream Decoupling & Filtering): This can contains subsequent filtering sections downstream along the power rail. After the main voltage passes through dropping resistors, the sections of C20 provide decoupled, lower-voltage DC to feed the earlier, highly sensitive parts of the circuit—namely the phase inverters, drivers, and the low-level preamplifier tubes (like V1 and V2). [1]
Why both channels share them
Vintage tube stereos from this era almost universally used a single common power supply to save space and cost. Because both channels pull power from these same voltage rails, a failure in either C19 or C20 (such as an internal short or lost capacitance) will typically cause a loud hum, low voltage, or a total loss of sound across
both channels simultaneously. [
1,
2]
If you are planning a restoration, you will either need to buy direct multi-section replacement cans or install modern custom PCB adapter plates under the chassis to restuff them with individual modern radial capacitors. [
1]
Are you experiencing a
specific issue like a heavy background hum or low output volume, or are you just getting ready to
recap the amplifier? [
1,
2,
3]
There is a problem where the right channel get distorted after about 3 minutes of run time. The pecs have been replaced tubes measure good on a tester.
Since the distortion takes about 3 minutes to appear, you are dealing with a classic
thermal runaway or component drift issue that triggers only after the amplifier reaches full operating temperature.
Because the tubes test well cold and the PECs (packaged electronic circuits) are new, the problem is highly localized to the right channel's output or driver stages.
The most likely culprits behind this specific symptom on the Eico 2050 are:
1. The Output Tube Bias Circuit (Thermal Runaway)
Even though the 7591 tubes measured good on a tester, tube testers test them cold and under very light loads. A tube can develop an internal grid leak or structural short once it gets hot.
- The Symptom: If a tube's control grid begins drawing current as it heats up, it overrides the negative bias voltage, causing the tube to pull massive amounts of current. The audio will distort heavily, and you might see the gray metal plate inside one of the right-channel 7591 tubes glowing bright orange/red ("red-plating").
- The Fix: Swap the pair of 7591 tubes from the left channel into the right channel. If the distortion moves to the left channel after 3 minutes, one of those tubes is failing under load despite the tester results.
2. Leaking Interstage Coupling Capacitors
If you haven't replaced the discrete coupling capacitors feeding the right channel's output grids, do this next.
- The Symptom: If a coupling capacitor leaks direct current (DC) voltage as it warms up, it will dump positive B+ voltage straight onto the control grids of the 7591 tubes. This destroys the negative bias, forces the tubes into extreme clipping, and causes heavy distortion.
- The Fix: Check the schematic for the coupling capacitors feeding pins 6 of the right channel 7591 tubes (typically 0.1uF or 0.047uF caps). Measure the DC voltage on the grid side after 3 minutes; it should remain steadily negative. If it drifts toward zero or positive, replace those caps.
3. Drifting Carbon Comp Resistors
The Eico 2050 relies on carbon composition resistors. As these resistors age, their internal structure degrades, and their resistance can spike drastically or open completely when they get hot.
- Grid Stoppers & Screen Resistors: Check the resistors connected directly to the right channel 7591 sockets—specifically the grid resistors (pin 6) and screen grid resistors (pin 4).
- Phase Inverter Resistors: A plate or cathode resistor on the right channel phase inverter tube (V5 or V6, depending on the channel layout) could be drifting wildly as the tube warms up, unbalancing the signal sent to the power tubes.
Next Troubleshooting Steps
- Watch the tubes in the dark: Keep the chassis open and run it for 3 minutes. Watch the right-channel 7591 power tubes closely. Do you see the large metal plates start to glow red right when the distortion kicks in?
- The Tube Swap Test: Swap the left and right 7591 tube pairs. Do the same for the preamplifier/driver tubes. This immediately rules out or confirms a thermal tube failure.
Let me know:
- Did the tube swap move the distortion to the left channel?
- Do you notice any red-plating (glowing orange/red metal plates) inside the right-channel tubes?
- Have the discrete coupling capacitors (outside of the PECs) been replaced yet?
the tubes were switched no change
Since swapping the tubes didn't move the problem, we can safely rule out a thermal tube failure. The issue is definitely caused by a
stationary component on the right-channel circuit board or tube sockets that is breaking down under heat.
Here is the exact battle plan to pinpoint the failure using a digital multimeter (DMM) while the amp goes from clean to distorted.
1. Monitor the Negative Bias Voltage (Most Likely)
The Eico 2050 uses a fixed negative bias voltage to keep the 7591 output tubes idling safely. If this negative voltage vanishes on the right channel as the amp warms up, the tubes will saturate and heavily distort.
- The Test: Connect your DMM (set to DC Volts) to Pin 6 of one of the right-channel 7591 sockets before turning the amp on.
- What to look for: When you turn it on, you should see a steady negative voltage (usually around -15V to -21V DC). Watch this voltage for 3 minutes. If it starts dropping closer to 0V right as the distortion sets in, positive voltage is leaking onto the grid.
- The Culprit: If the negative voltage drops, it is almost always a leaky interstage coupling capacitor (the discrete capacitors feeding Pin 6) or a failing grid-leak resistor.
2. Check the Phase Inverter Plate Voltages
Because you replaced the PECs, the early preamp stages are likely fine, but the phase inverter stage (which splits the signal for the output tubes) uses discrete resistors that handle high voltage and get very hot.
- The Test: Measure the DC voltage on the plates (Pin 1 and Pin 6) of the right-channel 12DW7/7247 or 12AX7 driver tube (depending on which position drives the right side).
- What to look for: Compare the voltages to the working left channel. If one plate voltage slowly climbs toward the full power supply voltage (B+), or drops down to near zero after 3 minutes, a plate load resistor is drifting drastically or opening up when heated.
3. Check for a Fractured Solder Joint or Bad Socket
Heat causes metal to expand. A tiny, microscopic crack in a solder joint—or a loose pin tensioner inside the vintage tube socket itself—can maintain contact when cold but pull completely apart after 3 minutes of tube heat.
- The Test: Chopstick test. Use a dry, wooden or plastic chopstick to gently poke and prod the resistors, capacitors, and wires around the right-channel tube sockets right when the distortion starts.
- What to look for: If poking a specific component or pin suddenly clears up the distortion or changes the hum, you have found a cold solder joint or a loose socket connection.
To help narrow down the exact component, let me know:
- Do you have a multimeter and feel comfortable taking DC voltage readings inside the live chassis?
- Did you replace the discrete coupling capacitors (the individual caps outside of the PEC blocks) during your restoration?
