Nice! I would fix it and use it. The leads should be plain old multimeter leads to plug into the banana jacks.
Here's how it's used: when troubleshooting an amp, inject a signal into the input f the amp (or into a subsequent gain stage). Use the probe on the signal tracer and just touch different components down the signal path. If you don't hear the signal at one point, you've just found the problem, it's just before where you stopped hearing the signal.
I've got a Philco signal tracer, the Eico looks like it has more functions. (RF converter?)
Have someone record a CD with a tone(s) on it and use that for a signal.
If you have an amp. or receiver that one channel works, use the tracer to "compare" one channel with another as you follow the signal towards the speaker\output.
Mark T.![]()
I''m sure you are right, Bill,,,
I think there are signal gen schematics in the RCA tube manuals,,,
I got the tracer for free at an auction... I probably passed up on a lot of equipment that may have been useful... I didn't realize I could use them, as they were being thrown in box lots, nobody bid on them!!!!!!!,
I also got a flyback transformer tester,, and a cathode tube rejuvenator... and other testers, that nobody wanted, for free (I already stripped them for transformers, pots, tubes, knobs)... Like I said, the reason I took the tracer was to part it out... On hindsight, I should have probably taken one of the 5-10 buck scopes, also...
Don't get me wrong, I appreciate all the help/advice I've gotten here,,,I have lots to learn about electronics work, audio etc...
Regards,
John
,,People on our sister site Videokarma.com might be interested in the flyback tester, cathode rejuvinator and other old TV related stuff.
Thanks for replying,,,
I'm not quite sure what you mean...Wouldn't any CD/tape work as an input, then? The guys at the Philco forum just use a soldering gun, and inject a 6V 60 cycle hum, and listen thru the speaker... I've done that before, and it worked.. but, I didn't have a tracer then!! I'll understand it better after I try it...
Thanks again
Regards,
John
I have found that a conventional music source has too many dips and pauses in sound to be a good source for troubleshooting, if a music CD is all you have, use it.
Mark T.![]()
