DaveG says on this page that the ST-40 OPT is 8250 ohms.
Nope, but Keg had no problem gutting stuff for fresh builds. I'm sure others have done so and a quick Google search should find something on any number of audio forums.You HAD his amp -- i am guessing its down the road - when you say that a stand alone amplifier - should be considered- did you have something in mind , any particular design?
Lets Hear more ! what is the design ? yours ?Here is an amp I built using the ST-40 transformers, and original eico tubes. One of the best sounding amps I have.
If OP is interested in this direction of SA-100 clonish mods, in addition to DaveG’s, Jason R. Thorpe published the schematic he developed here on AK (I think, some time ago, but I can’t find it now). Jason used the AA-100 transformer set, but the Eico ST40 set is close enough. But the feedback will need to be revisited with different transformers of course.DaveG's SA-100 clone uses 6BQ5's at over 400V B+ but with a controlled screen voltage via his EFB circuit. The ST-40 B+ is about 400V so could possibly work for 6BQ5's in the right circumstances.
I've done that. I turned a Matnavox 175 6v6 amp into a 6L6 amp using 6SL7 drivers.Nope, but Keg had no problem gutting stuff for fresh builds. I'm sure others have done so and a quick Google search should find something on any number of audio forums.
Looks like the EL 84 strategies are a viable alternative here --- I like the comfort of a design by Dave _ a respected designer - so this will be on the short listSomething a bit more offbeat might be to convert to 7189a type tubes. You could look at Dave Gillespie’s SA-100 clone thread. ST-40 voltages are in the ballpark (a little low actually) and the 7247 fits perfectly.
Teaser Pics -- Fisher SA-100 clone in progress
With a number of members working on some version of this amp -- either by way of circuit, use of Fisher transformers, or just that it's a 6BQ5/7189 amp, I thought I would mark my progress on my own version of this great amp. I had mentioned the basic features in a thread kpaxfaq started for...audiokarma.org
So the limiting factor was the Power Supply -- A do over would look like what ?I've done that. I turned a Matnavox 175 6v6 amp into a 6L6 amp using 6SL7 drivers.
The power supply had just enough oomph to do it along with using both 6.3v heater windings. It didn't put out anymore power, though.
Yes, I did it with Kegger's patient guidance, as documented in the back half of his thread at the time. I was a novice builder at the time.sounds very interesting - has anyone done this ? - i have both a Eico st 40 and just the transformers from another , - so two options with that iron.
Schematic --- Thread----
Just a little different sound really. I had two 175 amps. One restored original other than what needed to be done to make it a stand alone amp.So the limiting factor was the Power Supply -- A do over would look like what ?
