Hello all, I'm building a set of 3way triamplified speakers. Im using my Eico ST70 tube integrated amp. I would like to use the Eico for midrange duties, and use 2 Hafler dh220's amps (1)for the low frequency and (1) for the high frequencies. The Eico has no line outputs for connection to the other amps. My question is,can I use the tape outputs on the Eico for the 2 hafler amps? If this will not work,I also have a hafler dh110 preamp with the typical inputs and outputs, can this preamp be put into the mix with the Eico to accomplish the triamp setup?
Thank you for your time...
