Thank you Jack, that is good information. By the third time I read your response I was able to visualize what it is you are saying. The use of the turret boards encouraged me to see things in a modular type of structure. Although that is not compatible with the ideal grounding set-up you outline. I enjoyed the puzzle-like work of making everything fit on the turret boards. This adds a further piece to the puzzle, which I will modify.
As far as puzzles go, Mr. Jurich said I could get rid of the 10K resistors. He said their purpose was to provide for "unity gain." Am I correct in thinking that unity gain means the signal entering the device will have the same voltage as the signal exiting the device? If so, what is the potentiometer for? Do I not understand "unity gain"? Since I'm using the st70, which has no volume control, why would unity gain be useful, for me? What I'm trying to build is not just for a turntable. There are two inputs, one of which goes to the turntable preamp and, exiting that, to a switch; the other goes directly to the switch. That switch then sends whichever signal to the pots, and onward. Are all my ideas about what I'm creating just confused?
