EL84 Linestage
PakProtector
AK member
hey-Hey!!!,
I built a balanced output linestage to run my active cross over a while back. Originally ran 12B4 and then before solving a microphonics issue converted it to run EL86's. The EL86 worked pretty well, and once the PS was separated from the signal chassis it was pretty quiet. This circuit is a LTP, running a 36 mA CCS in the cathodes and 20k plate loads on a 480V B+.
Once I had it rigged to run the EL86 I just swapped in EL84's. Gain is a bit higher ov course. Microphonics are gone...:) sonics are at lest as good as the 12B4( and an improvement over the EL86 ). Triode strapped in both cases.
All in all a fine experiment, and suggesting good results for the next set of amps that will run EL84 pentodes as their input stage( E-Linear, for pentode 6CB5A outputs ).
cheers,
Douglas
Sounds like fun :yes: Do you, like Louis Wu, wait for magic smoke to let you know if you've over ampped the Pak library hardware? :D
Good stuff Pak, thanks for sharing the results and keep us posted if the experiment continues.
hey-Hey!!!,
First thing that popped into mind was an all-EL84 circuit. Linestage, front end and PPP power stage around a 5k a-a output trans...:) That and a 100-box of 6Pi14Pi-EV tubes...heh-heh-heh Then I could seriously simplify the tube collection.
cheers,
Douglas
I've been looking at an all 6BL7 schematic from an old Hi-Fi magazine for an integrated amp. Same thing, I have tons of them, so I may give it a try.
