nosrednakram
Hello,
I recently picked up an ELAC 770H but all isn't perfect. The big issue is the cue isn't hooked up and it doesn't appear to have the part. Not sure if this is the cause but the lift wouldn't let the record play until I screwed the bolt on the tone are all the way in. Now when playing by about half way through the cue list has risen enough that the record start's to skip. Looking for picture of part missing between cue lever and lift so I know what I'm looking for. Does anyone know if this part can be found on another model? Do I need the manual cue, and can I remove the adjustment screw from the tone arm and use auto and a hopefully steady hand? Love the sound came with a Pickering xv-15.
Thanks,
Mark
Thanks,
Mark
