Here's what I've tried on my 50H so far:
- Grado Gold with:
- Standard elliptical stylus
- 8mz microline stylus
- Elac STS 444 with 344 elliptical stylus
- Audio Technica AT3600 with:
- Standard conical stylus
- Upgraded LPGear elliptical stylus (this is what I'm currently running.)
- 3 mil stylus for 78RPM playback
In addition, I have a Technics SL1200 MK2 with an Audio Technica VM540ML set up for more critical listening, and a frame of reference for what detail is being lost with cheaper styli.
This might ruffle some feathers, but it's been my opinion for a long time and I haven't been quiet about it: despite being the most expensive thing I tried on the 50H, the Grado Gold sounded the worst to me in this setup. I keep that cartridge around in vain hopes that it's going to work well with some table eventually because people have no end of praise for Grado, but no matter what I try it sounds dull and sibilant to me. Would not recommend the Grado.
The STS 444 has a very nice sound. Not the most detailed but quite pleasant. It has very nice bass, not boomy but room filling if that makes sense. This is what shipped with the table, it has its own headshell and I'll swap this on from time to time.
I find the AT3600 with the LPGear elliptical the best compromise setup. The conical is okay, but has noticeable tracking issues towards the middle of the record and the detail really isn't there (but it's good to keep it around for the occasional record that has some damage that the conical doesn't pick up.) The elliptical tracks quite well up to the inner grooves of the record (some slight IGD becomes noticeable on loud tracks right at the end of the record) and is actually pretty close in sound to the 444, which was a surprise to me given the price and age difference between these two carts. It's close enough to where I tend to run the 3600 more, just because it's is so easy to swap styli for 78RPM playback; the 444 technically has available 3 mil styli but they're a massive pain to find and not cheap.
Obviously a 3600 isn't pulling nearly as much detail as the VM540ML (which to me is reference level, close to HD FLAC quality on some records) and rolls off the highs to a degree, but it sounds quite pleasant, and it works with how I'm using the player.
My 50H is my "jack of all trades convenience" deck while my 1200 is my more "audiophile" oriented setup. I often use the 50H as a background music player, and don't shy away from the changer spindle; an elliptical is forgiving enough of VTA misalignment that I can get away with stacking the 10 records Elac says that the table is capable of without noticeable loss in fidelity. The 3600 is also stupid cheap, styli are easily sourced and great value for the money. That shouldn't be seen as an insult to the 50H as a table or the cart; in honesty I tend to run it more than the 1200 these days.
