I recently had the good fortune to acquire a 50H that appears to be remarkably good condition. However, when I play, I get a thumpa - thumpa sound from the turntable, continuously repeating with no silence in between. Playing at different speeds (other than 33 RPM) causes the same problem.
I'm brand new to working on turntables and understand that the most likely cause is a flat spot(s) on the idler pulley. But, before I spent around $40 to have the idler re-rubbered, I'm wondering if there is any other likely cause I should check that would cause this continuous thumpa-thumpa when playing?
Or... is there a good way to confirm that it IS the idler pulley? Visually I don't see any evidence of flat spots (although perhaps these are unseen to the naked eye?).
Thanks in advance for any suggestions. Right now, this noise is too loud to enjoy the turntable.
Cheers.
Cheers.
