Thanks fo all the help.
I have ordered new caps and resistors from Dayton Audio, did not go for Clarity caps because of the price differance. Opted for 4.3uf 250V instead of 4.5uf and 12uf + 1uf for the other 13uf cap. Resistors are 10ohm, 10w.
I have measered the woofers and mid range speakers > woofers measered 7,3Ohm and Mid 6,9Ohm. I have cleaned the 2 pots with contact cleaner and when all the above part arrive I will solder all speaker wires to there respective drivers instead of using the female plugs that are oxcidaded and get the technical stuff done.
With regards to the cabinets that are in good shape, I will restore them but don´t like the dark color so I will sand them and oil (Trying to get something like the photo in attachement). I dont like the fronts so I will make new fronts like the EV Four ones or like the Wharfedale Dovedale fronts, just one big clouth in light color instead of black.
With regards to the part of the cabinet that you can see if you take off the grills, I was planning to stick black feltro on it so it is nice and black and when drivers are installed it will create a nice seal and it also can act as sound dampening. What do you think about this instead of just black paint?
3 more pictures of the drivers, woofer back + tweeter
I will keep this thread updated
