Electro-Voice Interface 2 ???
udors
Member
Recently getting interested in old speakers had me take a close look at the pair being used in my auto repair shop for the last 15 years. They're a pair of Electro-Voice Interface 2. Thought they might be special, googled and found that they just may be special. So - took them home, took one apart and now I'm puzzled. A 7" woofer, 9" passive radiator, and a 3" tweeter with a baffle in front of it. Reading the threads learned about passive radiators. Neat. What's got me puzzled is the simple crossover made up of one capacitor, a variable resistor, and nothing else. What about an inductor? Not needed? Does this speaker call for an external crossover? Is it worth the money and time to replace the surrounds? Capacitor?
the capacitor in the crossover prevents low frequencies from reaching the tweeter. an inductor would be used to roll off the upper frequency response of the woofer. without an inductor, the woofer covers the entire frequency spectrum, at least to the extent of its ability to do so. many speakers were designed this way. i would say go ahead and refoam them, and while you are at it, replace the crossover caps and clean the level control with deoxidant. check that the cabinet and drivers are fully sealed. then let us know how they sound!
Heck,yeah! I'd have the woofers and passives re-edged,or do it yourself.I haven't looked these up on the Telex support archives,but I've always thought EV didn't build real cheap stuff at all.I'm with lguise- replace the cap,too.The passive is stamped,is the woofer frame cast? I'm also thinkin' it's a "SuperDome" tweeter.
added- The woofer surround looks like it's seen better days,too.I've got a pair of EV FR12-2's that I need to rehab.I just don't care for this type of surround(can't remember the name of it now,mine have the same stuff)The pleated accordian cloth seems to hold up for many years.
The first real speakers I bought were EV interface 1 series II. I loved them, and still have them. Unfortunately the 8'' woofer surround rotted out and I put in some cheap Pioneer replacements. I did not know about re foaming 12 years ago. Worst yet, I threw out the original woofers. :bash: I keep searching for those on various sites.
Will do
Thanks for the interest.
The woofer frame appears to be stamped steel, but has a fairly large magnet on the back. The surround is some kind of rubberized material. Can I use regular surrounds there? The passive radiators (badly blown out) are regular foam, shouldn't be a problem. The cap is a TI made in Mexico, 4.5mF 40V NP. Easy from Parts Express. Anyway, these shall be restored. I had already downloaded that file describing the EV Interface speakers. Figured that anyone who describes their speakers that well must be proud of them.
I just finished re-capping and surrounding a pair of early Large Advent speakers. Easier than I thought, and oh how sweet they sound on my SX-1250. Wish I'd been aware of the possibilities a couple of years ago. I dumpstered a Large Advent I'd had since new in '72. Any one have an orphan to go with the one I kept?
My few remaining brain cells are sayin' the woofer surrounds are 'special crap',but you can get it,and that's what I'm going to do with my FR12-2 woofers.It looks like the same stuff,and yours might be real stiff,fatigued,and crack easily right now.EV/Telex support might sell it,or Orange County or a real EV service center.A guess is that the passive would be OK with a good aftermarket surround.Don't hold me to anything,though:D Gotta say,these look like entry level for EV speakers.I was hoping to see cast frames and superdome tweeters.Still good stuff.
Hey Terry, Thanks for the tip on the woofer surrounds. One more thing, does anyone know the ebay user name of the AK member who sells surrounds on ebay? Try to keep it in the fold.
Unless it's torn, the woofer surround should still last for quite a while. Just refoam the woofer and try them. I have a pair that I replaced the PR foam and still have the original woofer surround. They are a very good speaker! IIRC they are a fav of GordonW
Just noticed that you have the EV2 emblem on the baffle, even though the grill is missing!
I have a set exactly like those I use every day in my office system. The were Boston A60's that got displaced by some KLH 17's that got displaced by these. I love them for what they are. I liked them so much I jumped on the chance to get some minty Interface 3's which are amazingly good for essentially a 8" 2 way.
Mine were trashed and one step away from the dump. Glad i took the time.
Fixem and enjoy.
My rebuild - http://www.audiokarma.org/forums/showthread.php?t=131307&highlight=interface+2
The interface 3's - http://www.audiokarma.org/forums/showthread.php?t=197712&highlight=interface+2
and check this... http://archives.telex.com/archives/EV/Speakers/EDS/Interface 1,2,3 EDS.pdf
udors-I might have steered you wrong on the woofer foam surrounds-I see OC speaker has some liquid coating you put on them.My FR12-2 woofer foam has the same look as yours,and they seem to have a waxy-looking "coating" brushed on.So they may not be all that special,just coated at the factory.Since one of my speakers hung in a church for a while,the other stayed in the box in the backroom of our lighting and sound contractor.Only 1 woofer foam has cracked,but both have age on them.I'm sending mine to KC to have the cast woofers and dome tweeters brought to as close a match as possible.
Which caps?
Got hr new surrounds glued in. Now, about proper caps. The originals are 4.5 mF 40V NP electrolytes. I would like to replace them with Polys, but am finding them to be either too high (4.7mF) or too low (4.3mF) at Parts Express. Would it be better to go a little larger capacitance than original?
Which caps?
Got the new surrounds glued in. Now, about proper caps. The originals are 4.5 mF 40V NP electrolytes. I would like to replace them with Polys, but am finding them to be either too high (4.7mF) or too low (4.3mF) at Parts Express. Would it be better to go a little larger capacitance than original?
I would use a 4.7 Jantzen Crosscap or Z-Standard in there. .2uF is well within 5% tolerance. If you wanted it to be exact, you could parallel a 3.9uF with a 1.5uF and bypass with a .1uF.
I have been using the Jantzen caps in my speakers lately, and I really like them.
Resurrecting an old thread here, but I picked up this Interface Series 2 set from Udors last week (very cool guy btw). At the same time, I picked up a set of CS-63DX speakers as well. Traveling back and forth between Denver and Savannah, I hadn’t had time to exercise them until tonight. Simple setup - Denon AVR-3000 fed by a DN-300Z for Bluetooth signal.
Just doing a little A/B comparing and I have to say, these little E-V are badass. They do punch well above their weight, and while the CS-63DX’s definitely need some work, if I had to choose right now the E-V’s stay. I don’t feel the need to have a sub with them, but the Pioneers sound anemic on the low end. Just FWIW….
z
