I’ve listened a lot to this amp now, and in general, sounds really great and it’s amazing the detail it produces, especially at the very high end, and low end... I run treble flat, but have to turn bass way down to only ~20%
the pwr transformer definitely gets darned hot, and I will see if this continues after I do a thorough parts check and some parts replacements... if so, maybe I will rig up a heatsink to it, and/or even a small fan(???)... I can’t see how all that heat won’t eventually take a toll
Q1. previous owner replaced 2 coupling caps with large orange squarish films, value 0.1 mfd / 630V... apparently these caps are quite a good... the specs say to use 0.047mfd / 400V... is it OK to go up in capacitance like that?... what will the effect on sound be, and could it explain my excess bass?... I can get .047s, would it be good to put those in?... would it be worthwhile to upgrade these?
Q2: based on schematic, are there any particular locations where I should put in "audiophile grade" parts to have an actual audible effect on sound quality? (especially the caps and maybe resistors)... I don’t mind investing a few $ if it’s actually worth it, and while I’m in there with a soldering iron
Q3: when I use the “balance” control, it seems to act like no other balance I’ve ever used... it does not simply move sound on/off from left to right, with center position being an equal balance... seems somehow more complicated than that, and can even cause distortion at the extremes... do you think this control is acting normally, ie., has anyone ever experienced a balance control like this?... here’s how the specs describe it (which perhaps sounds like a “fancy” balance control?):
http://screencast.com/t/qcKifxNaxtF
Q4: when I replace death cap with a safety cap, should I use basic blue ceramic disc version, or the square type that also includes filtering?... also, I assume death cap goes on hot lead from wall power? (I will probably swap in a new 2-prong *polarized* cord)
Q5: should I use carbon comp resistors to preserve sound quality?... or do other resistor types sound the same and are quieter and more robust?
would love to hear your any thoughts one the above, thank you!
