I recently bought a Marantz 2250B and I am disappointed in the way it sounds. The sound is strident/harsh/bright rather than the warm/lush sound I had read about in the Marantz forum. The person I bought the unit from was an analog engineer and had replaced several electrolytic capacitors “on the tone board”. He had paper work which he gave me and I have scanned for your review. I am wondering, did he not go far enough and should have replaced more? I have been watching “Morgan” who does restoration of Marantz units and then sells them on eBay. More recently I found a Sansui Seven in mint condition that meets all original specifications. I sent Jerry a question about the Sansui asking whether he had done the same work as Morgan on the Sansui:
Morgan’s work:
Diffuser paper behind the tuning scale replaced to restore that classic Marantz blue glow! Power supply electrolytic capacitors replaced for increased reliability. Tantalum capacitors on tone board replaced with electrolytic capacitors for improved performance. DC electrolytic capacitors replaced on Phono Amplifier, Tone, Audio Power Amplifier Boards for improved reliability Audio power amplifier Forward Bias and DC Offset set to factory specifications. Power supply voltage set to factory specifications.
Jerry’s response was that the Sansui Seven met all original specifications, but his work was not a restoration like Morgan. He could do a full restoration for an additional charge.
What does aged electrolytic capacitors that need to be replaced sound like? Could a receiver meet all original specifications and still need to have aged electrolytic capacitors replaced? In the case of my Marantz 2250B, are there other electrolytic capacitors that need to be replaced and are responsible for the strident/harsh/bright sound or is this unit just “bright” as some have said in the Marantz form?
Morgan’s work:
