Here are some pics of the Interface A Series III EQ:
It has writing on the rear panel as follows:
"THIS EQUALIZER ONLY FOR THE INTERFACE:A SERIES III, B SERIES III, OR C SERIES II SPEAKER SYSTEMS INDICATED ON FRONT PANEL"
I've typed up some information from the Interface B Series III owner's manual as found here:
http://www.electrovoice.com/downloadfile.php?i=971391
This information is in the section which relates to running different types of interface speakers from the same amplifier, and therefore advises on which speakers can be used with which EQs. It highlights the subtle differences between the various series of speaker and the accompanying EQ:
"Interface B series III and Inferface C Series II use the same equaliser. Therefore, in a system set up for Interface B Series III, Interface C series IIs may be added to the same amplifier and will receive the proper frequency contouring.
Not unexpectedly, the capabilities of other equalised Interface models are best realised by using the equaliser specifically designed for each system. The deviation from ideal depends on the particular model.
The Interface A Series III is not endangered by the Interface B Series III equaliser as long as very low bass (around 30hz) at the highest listening level is avoided. Frequency response from the 40-80hz range will be depressed about 3/4dB and approximately twice normal power will be fed to the woofer below about 32hz.
Interface D is not endangered by the Interface B Series III equaliser. However, response below about 28hz will be depressed about 3dB and response in the 40hz to 80hz range wil be emphasised by about 3/4dB."
