Emi Dls529x
BrandXRC
BrandXRC
Just picked up a pair of EMI speakers along with a Marantz 2325 Receiver. They are model DLS529. Oval woofer, 2 way, metal grilles. Sounded pretty good with the Marantz at the Garage sale...Does anyone have any info on these. The cabs are a little rough, So if they are keepers, they will require some work...Any info would be appreciated...
Hi,
They are English made. Very well thought of there. EMI made their own woofers at least. Very high quality build and were mainly used in the high end there. 1960's through 1970's vintage. Worth owning. Some of the EMI woofers were used in other British speakers like Chartwell.
Yes - I have a pair of EMI LE4's, which use the same elliptical woofers. They're beastly 3 way things with an elliptical midrange and two 2" cone tweeters to complement that woofer. The tweeters are not that great at all to my ears...harsh and roll off way too soon.
The woofer is a very good unit with a huge magnet and a hefty cast frame. However, on mine the cone had sagged, but rotating it 180 degrees sorted that.
Any chance of some photos? I'll dig out a few pics of mine for you.
As Kent said, they are indeed British made with nice solid cabinets.
There are a couple of thread on DLSs, but here's what I know. DLS stands for (ahem) "Dangerous LoudSpeaker". So much for british reticence. EMI used an elliptical woofer with an aluminum center and pulp outer part, which I think allowed the upper end to be better and extend higher than a uniform construction cone would, and the elliptical shape both spread resonances out so they were less noticeable, and allowed better dispersion (in one dimension) than a round driver would, while getting some of the low end that a large driver can provide. I agree with the previous poster that the tweeters on the DLSs don't sound particularly smooth or extended, but that may be a capacitor issue -- my earlier pair of EMIs with a single slighly larger coaxially mounted tweeter sounds much nicer.
Ellipticals have an unwarrented lousy reputation because of their use in car stereos in the 60s and 70s. The speakers used in cars back then were designed with no regard for their actual use, and efficency/loudness and durability were the only important criteria, apparently. And it was pretty obvious when you listened to them (of course the eighttrack may have not been the best source either).
But the EMI elliptical was a different beast, good enough that it has a following in the full range world, and in the 70s, Monitor Audio used them in their top model speaker (and, oddly enough, used them mounted at a 45 degree angle on the baffle).
PICS
