So I finally had time to take a look at it and the problem stays with the speaker and does not travel with the tweeter.
Possibly a bad cap in the crossover.
What kind of speakers are the EMITs in?So I finally had time to take a look at it and the problem stays with the speaker and does not travel with the tweeter. Any suggestions?
EDIT: Also, a screw was sucked onto the thin plastic diaphragm from the magnet and dented it a tiny bit, I'm not sure if this will affect the sound.
As long as the metal trace hasn't been cut, I don't think the damage will affect the sound.
I have very little soldering experience but I'm pretty confident in my DIY experience.Since those speakers don't have built-in level controls, it's mostly likely the crossover, either a cap (as mentioned by @seifreit) or other component. Due to their age, replacing the capacitors is probably a good idea. Do you have any soldering experience? How about general DIY ability?
Watch a few Youtube videos to brush up your soldering skills. The crossovers in your speakers aren't too complex, but they are on printed circuit boards, which is a little more involved than just soldering wires together.
This thread has a pretty good explanation of what's involved in recapping. This thread documents someone's earlier restoration of these speakers. Take pictures as you work to document what goes where. If you get stuck, you can always ask here (maybe start another thread rather than continuing this one).
Good luck.
ETA: In fact, before you do anything, I'd recommend starting a new thread for this issue, rather than piggybacking onto this one, detailing the symptoms and the testing you've done so far. Because it was a reply, fewer people will have seen this one.
You're welcome, but I was remiss by not suggesting swapping amp channels. That's usually the first thing we recommend.I want to thank you guys for helping me through this, I would had just replaced the tweeter without even checking to see if it was a speaker issue (which led me to my final diagnosis).
Simply drop the foil strip onto the sticky side up of inexpensive acetate(scotch) tape.
Cut off the excess.
Bridge the gap.
That diaphragm is toast and was before you attempted to re-flow. Traces appear to be burned and overheated from use.
The blue arrows are usually where the cold joint problems are.
New diaphragms are in order. When attempting such delicate soldering(red arrows) experience and flux are a necessity.
Good luck,
Mark K.
What model are these emits from?
