repeater
Hello everyone. Very long time lurker, first time poster. I've done some looking here and there and can't seem to dig up an answer, and was hoping someone here could help.
I own a pair of RSII's and just acquired a set of RSIIb's that I'm currently restoring and modifying. My question is in the differences of early EMIT magnets.
The RSIIb originally came with a forward and rear firing EMIT with the 490126 PN on the back. They also have a front firing 490123 "super" EMIT as well, that uses the thin magnet. All use the same diaphragm. Two of my EMITs were damaged and when replacing them, I sourced a pair of the round front plate EMITs that look like those used in the InfiniTesimal. They also have the same diaphragm (which is all I wanted) but they used a 490124 thin magnet.
So now, I have both magnets in front of me, ready to put these EMITs back together with their new diaphragms. Which magnet should I use? The original 490126 "thicker" magnet, or the 490124 "thin" magnet?? Just for reference, the RSIIb's are going to be ran with an active crossover, so original crossover specs don't need to be the reason of using one or the other, I'm just curious because I'd assume there's some sort of frequency ability difference between the two magnets, as Infinity used the thinner magnet on the "super" EMIT in the RSIIb, but also used the thicker magnet as well, yet both have the same diaphragm. As you can see in the picture, the magnets certainly look like different material. Is the original, thick magnet Cobalt Sumarium? The thinner? I'm confused because they both have a different look and color (see pic) yet are both from roughly the same time period. Any help on these is appreciated, I'm just curious as to whether any particular magnet yields better results. More to come on these crazy RSIIb's I'm building.
