Hello all,
I have an Empire 598. Overall in excellent shape, however the plastic contacts forward of the headshell collet have cracked (disintegrated with age).
Can anyone recommend a service center that repairs Empires and might have parts?
Thanks in advance!
I interpreted the OP's comments as meaning that the arm contacts had disintegrated, rather than the sled having problems. If it's the arm, the problem seems likely to be harder to solve..
My only issue with the sled from Pat’s was that the mounting screw threads, though they appear to be the correct (and uncommon) 3-56 size, were likely cut with a dull tap and were too tight. I ran a sharp tap through and made ‘em happy.
There are occasionally genuine Empire sleds on ebay but you’ll want to be careful buying them. Seems people want to sell you their broken ones, so take a close look. NOS sleds can go for way too much money, but you could get lucky..
Just get a Pat’s but ask them to check the threads before shipping. I had messaged them about the issue with mine, and they said they’d check the problem out.
BTW - current listing # for the Pat’s sled is 301558683160 .
There’s also another seller of aftermarket Empire style sleds and when I researched, was told that they’re fine too. I went with Pat’s though, as they come from nearby.
Thanks Montycat. Maybe your post is the one I’m thinking of. Sounds like something unique to the Dual that caused additional “wear” someplace? Are you talking about wear when changing sleds/carts?I don't have direct experience with the aftermarket printed or molded Empire sleds but I posted the thread that compared the Dual ones. The hive mind seemed to favour the molded versions; I know I did/do. That might be subject to some debate with the Empire ones and perhaps even a non issue. If the shape is right and threads are good it should be fine. You won't get the wear we had with the Dual, and you won't see it once installed so the colour and texture won't matter.
