RTally
Speaker addict
Last year I bought a pair of EPI 120B speakers for little money. When I got them home, I tore into them and discovered that someone had replaced the original 10" woofers with Radio Shack Cat. No. 40-1331B drivers. Bah!
Well I finally found some replacement woofers. The pair of drivers cost me less than one replacement driver from Human Speakers. (I am cheap.) They look to have been refoamed with flat surrounds with the outer flange glued on top of the speaker gasket. I know EPI did that with the 8" butyl surrounds, but I have never encountered it with foam surrounds.
Picture of woofer. Based on comparison to pictures of other woofers and the similarity of the rear label to that I see on other EPI woofers, I believe this is the correct driver for the EPI 120B.
Closeup of foam showing outer flange on top of a thin fiber gasket. The gasket is paper fiber, about 1/16" thick. It is not the remnant of the previous surround.
The foam is supple and does not seem ready to disintegrate. The flat surround is not planar with the basket edge. Instead, the inner flange is a bit lower at the roll than the outer flange.
I am rebuilding the 120B with new caps and rear speaker terminals. I have new foams of the Boston-fillet style that appear to be the proper size. I am going to refoam because that flat foam has a narrow roll (1/2") and the cone shows little excursion, definitely less excursion than the EPI 8" cones.
My question is, when I refoam, should I attach the foam to the steel basket or should it go on the gasket. My guess is that the foam should have been attached directly to the metal basket.
