EPI tweeter magnet / does size matter ?
mr.jones
AK Subscriber
Over a year ago the magnet fell off the back of a tweeter of my SARAS speakers (the California made brand not the Linn). This damaged the voice coil. I inspected the other tweeter and its magnet was ready to go too.....I guess the glue has deteriorated with age.These are inverted dome tweeters and look just like the masonite inverted dome EPI tweeters from the same era so I got a pair of these from eBay as a replacement.
I finally am getting around to fixing these and notice that the magnet from the SARAS are twice as big as the EPI magnets. Why would SARAS put such a huge magnet on their tweeters? Does the larger magnet change the efficiency or sound of the tweeter? Can I still use the same size capacitor in the crossover? I am afraid of damaging the drivers or crossover if the are not compatible.
Thanks.
Hey Celt...what if the DCR is compatible? The SARAS are hand and replacements impossible to get so I am trying to match them best I can.
Thanks.
Match sensitivity and impedance as close as possible if you want to avoid having to re-work the crossover.
The f/S (crossing frequency) of the driver needs to be as low as the current one too.
OK...thanks.
More magnet can help in various ways, all equal and just a bigger magnet will be more efficient/sensitive
with lower Qtc because the magnet will lower Qe.
A longer voice coil could be used to give it more linear throw for a lower crossover frequency.
EPI used different size magnets during early vs. later production.
Do you know if the SARAS' tweeter had ferro fluid or thermal grease or none?
Ideally, you'd match Fc, Qtc, impedance, sensitivity, thermal capacity and response flatness.
What's wrong with the original tweeter - open circuit?
