anytune
I bought a replacement inverted-dome, masonite-flange tweeter for an EPI M90. The tweeter works, but the terminals are unmarked. I have looked closely and cannot find any indication which one is positive and which is negative.
I tested the tweeter briefly using a very low audio signal, then reversing the cables, and could not hear any difference.
I know that with a woofer, wiring it backwards (out of phase) will sound softer with less depth. But again, I can't tell any difference with this tweeter.
The other EPI tweeter, looking at it from the back with the terminals at 6 o'clock, is clearly marked left terminal positive.
Question: Does anyone know if left/positive was standard for these EPI tweeters? If not, is there any risk of damage if I happen to hook it up backwards? Thank you for your assistance.
