I think I made a mistake throwing the cabs out. Sound like most of you would have fought each other for a set of mint cabs. As for the tweeters I could pass them on to someone else that needs them or hope I find another set of EPI. Oh and I forgot to mention I kept the EPI logo off the grilles. I also took a picture of one of the woofer I kept out of the cabinets. I dont think Its valuable at all. Says made in taiwan R.O.C 8 ohm sw820pp. Can someone identify the woofer (if its even possible) so I dont end up making another mistake again and end up throwing a good woofer in the trash. If its trash its going in the trash were it belongs.
AudiO.
I hope you realize my and other posts were NOT intended to insult you in any way. As the old saying goes: **** Happens.
Save the tweeters and logos. Maybe some day, you'll come across a set of EPI's or Genesis speakers that need a rebuild.
And yes, most of us who own EPI's would have brawled over mint boxes and grills. :yes:
As for the single driver you have. It's likely not trash, but more on the order of a RadioShack replacement driver. Some were good, some not. I never throw away drivers unless they are non-working or torn beyond repair.
That being said, it's yours to do with as you please.
If you want to play around a little, mount the driver in a cardboard box. Hook it up to your amp, and see (hear) how it sounds. A box with about 1.5cu ft. size should be good.
To find the cu. ft., multiply the height x width x depth, then divide by 12 three times.
This hobby is all about having fun. Go have some. :thmbsp:
