highwaychile
Well-Known Member
I know this subject has been discussed at length , but I didn't find anything specifically dealing with the connections for a vintage preamp and power amp. I have an SAE 180 Parametric coming tomorrow so I wanted some comments on how I currently have an EQ running through my system.
I have the output on a Technics SH-8020 Graphic EQ connected to the DAD input of a Luxman CX-100 Preamp. (The Preamp is directly connected to a Luxman M-2000). The input on the EQ is connected to the ouput of a Denon CD player. I then select SOURCE on front of the EQ. The only other source I'm currently using is a Panasonic Blu-ray player which is connected to the Tape playback connection on the EQ. When I play a Blu-ray I select Tape on the EQ.
Would I improve S/N by connecting the EQ to the Tape 1 In/Out on the Luxman Pre, connecting the CD player to the Tape Playback on the EQ and then connecting the Blu-ray to Tape 2 or other in on the Pre?
I realize I'd lose EQ for the Blu-ray this way, but CD's are 95% of my use of the system so I'd sacrifice if that's the best method for connecting the CD player.
