anyone tried a pa system eq? like a 32 band?
ive been kicking that idea around as well...
I don't think you really need 32 bands with a parametric equalizer. Usually 3-4 "nodes" are enough and with 6-8 you can do wonders.
I have 2 parametric equalizers, 5 nodes stereo each (Technics SH-9010) that I have used. I also have a 2x33 band graphic equalizer.
And then I have a room that sounds ... not so good.
I have measured the room with REW (Room Equalization Wizard) and it has peaks and nulls around the primary modal frequencies that span abou 25~30dB (when the room is untreated).
It's certain that the equalizer can't correct such peaks and nulls.
The problem with room correction is that the fault isn't just a frequency response shaping issue. The main problem is in the "time axis" with reverberation, flutter echoes and frequency response dips at the frequencies where standing waves are formed.
And the most interesting issue is that the problem is different in every different spot of the room. Do a measurement with a mic located where your right ear should be, get a picture. Measure again where the left ear should be, get a different one.
I don't believe the rooms can be corrected by means of an equalizer. Speakers and sources perhaps. A 6dB/octave rolloff in the bass can be smoothened to 3dB/octave for an octave or so using a single node of a parametric equalizer. A trebble shy cassette tape can become more listenable if the high frequencies are slightly boosted. A dip or peak in the loudspeaker response at certain frequencies can be attenuated by setting a node at that frequency, selecting the appropriate Q to encircle the bandwidth required and set the level to increase or decrease output at that zone.
But the rooms require a much more targeted aproach.
