C Hart
Hello solid state gurus. Thanks for checking out this thread and for any help you can provide. I have very little experience in repair or rehab on solid state components, and I hope someone can help me with suggestions for an equalizer that recently started misbehaving.
My Alesis M EQ-230 30 band graphic equalizer until recently worked silently and effectively. At some point it developed a small but noticable 60hz hum when the "EQ In/Out" switch on the unit is engaged. Here is the behavior:
- The hum is present when the EQ is "In".
- There is no hum when the EQ switch is "Out" nor in any other setting or component.
- The hum appears on both channels when both are "In"
- The hum disappears from each channel when the switch for that channel is "Out", i.e. if one channel is "In" that channel hums, if "Out" it does not.
- The EQ slider settings do not affect the hum.
- The preamp volume does not affect the hum
- The amp gain affects the hum
I do not think there is a ground problem outside the EQ. But in the interest of completeness line power is through an automated power strip with the following connections:
Main sensor switch: Adcom GTP-500 preamp
Unswitched: Technics SL1600 turntable, Sony CD/DVD player
Switched: Yamaha P3500S amp, Realistic APM-300 power meter, Alesis MEQ-230 equalizer
Component connections:
Preamp in: CD, Phono, Bluetooth adapter, Mac Mini/DAC
Preamp out: EQ
EQ out: Amp
Speaker connections: (parallel) (2) JBL L166, power meter
Can anyone provide some troubleshooting advice on this? I am not sure where to begin. Many thanks!
Preamp out: EQ
EQ out: Amp
