ESR reading
by the way
Most of the capacitors on this board read high uf while in circuit. Some of the ESR readings seem extremely high, 9.0 and higher. I don’t believe all capacitors are bad with high uf readings in circuit, but I do think the ones that the ESR readings are high need replacing. Should I look past uf readings and focus on ESR readings? The capacitor being tested in the picture is 47uf 6v.
I have replaced 2 already, but I’m also looking for tricks to hold these tiny capacitors in place so I can solder the new ones in? No room for error on these.
1D047350-ADFA-465B-8B5B-10F0383B9564.jpeg C458802E-4C2E-4F37-9779-B4E01744914C.jpeg 2D144D59-3D08-45DB-B9B0-3E99F54391CD.jpeg
for reasons that I do not understand, caps that have high ESR also seem to read high in value. Not sure if thats just because of how the testers measure things or what but a cap with very high ESR is not a happy cappy.
also not sure how accurate those measurements are in circuit.
ESR is a measurement for how functionally effective they are, independent of whatever the capacitance may measure. It's the one that counts for replacement.
