I was thinking the eminence as well. However, it is a 8 ohm speaker. Would that cause problems?
I'll have to get those pulled out and check. According to hi-fi engine both the amt1 and amt4 were 4 ohm speakers.I don't know if the stock driver in the AMT1 was 4 ohms. The one ESS sells at the moment is, but that doesn't mean squat for a 40 year old speaker, I guess. Are any of your crossover components marked for their values? That would be a pretty good indicator of what the impedence needs to be on the drivers.
Thanks! They do look really unique. I plan to run them off a Hafler dh-200 when all is said and done.I had a pair of AMT 1 pedestals, which is what I believe you have. They were 10 inch woofers ported on the bottom in a pseudo transmission line design. The speaker cables also connected on the bottom. If these are the same, if I remember correctly, they used a modified 10 inch driver designed specifically for that box. I have a PDFs or something talking about it buried somewhere. The cabinets were 4 Ohms. I don't remember what the drivers were.
They were outstanding speakers when driven by a good high current amp such as a Yamaha M-40. I miss them sometimes. I love the look too! I loved it so much I ended up getting a pair of AMT 1aM towers. They have both moved on, but the towers were comparable to my Kef 105s, but slightly different with different strengths and weaknesses.
Good luck with those replacement drivers.
Now you have me really thinking porkloin! A downfiring sub, relocating the speaker jacks to the back and build a separate compartment in the middle. Well, maybe down the roadOf the three drivers mentioned, the Eminence seems to be the best fit. Although billed as a good direct replacement for ANY ESS 10" driver, they need a 2.75 cubic foot enclosure, which rules them out in any of the dual woofer speakers, such as the AMT3. The Goldwood and Dayton are better suited in the dual driver scenario as they need less volume and don't go down as low (damned physics).
Converting the pyramids into 3-ways is easy enough if you don't want to put the stock grills back on. DC Gold makes a mod that I'm sure sounds quite nice, but lacks the imagination necessary to maintain stock dimensions. A bit of work on the calculator and selecting the correct woofer for the volume and you could probably put in a downfiring woofer and throw one of those new-fangled full ranges into the original woofer hole (with the appropriate enclosure behind it).
I could go off on tangents all day long.
Congratulations on your membership into the cult of Oscar Heil.
Now you have me really thinking porkloin! A downfiring sub, relocating the speaker jacks to the back and build a separate compartment in the middle. Well, maybe down the road. I like how your ess turned out!
Automojo-I've been reading up still alot of the posts on the amt3s. When I go to redo the crossovers I was just going to recap them, but you mentioned going with a heavier gauge on the windings or the inducers? (sorry for my terminology lol). I've never really worked with crossovers before so are these parts interchangeable? Just buy new with the same values and solder them in?
