"Yep. All you have to do is crank the tweeter level up a little. If you can, move the dead tweeters to the outside of each speaker's arc-of-tweeters."
Yah I did. The way I have them setup in the room there in (a lot of placement tryouts)
is I sit behind them and they fire angled to a point in front of me with the hot tweeter
inside and the other 2 outside. I have them setup as no tweeter,hot tweeter,tweeter,
tweeter. They are also mirror image so you could put them on either side then all of the
tweeters will be inside out or the other way would be outside in but either way you do
it they will be identical on either side so you can have many different placement options.
The tweeters do have an adjustment on back at -3,0 and +3 I have them set at 0
with plenty of high end, nice mid and solid low notes.
Yes I got them for a very nice price from a thrift store. The cabs are in decent shape,
all the woofers are nice including surrounds, each has 1 bad tweeter and most of the
grill is shot on both, which I'd like to redo with something a little more modern looking.
I am still not sure if I can keep these things as my house is full/don't have "good" place
for them to truly breath. But will see! If I was to sell them I would not want to have to
ship these mothers!
