Nope.
So - what do you mean by "ESS Heils" Are you referring to just the HiFreq drivers, or a complete Heil speaker with woofers & the ESS drivers?
Below shows a pair of Heil Air Motion Transducers with a simple HighPass network used as superTweeters with a pair of Altec Valencias.
You really need at least woofers with the Heils to get a full range sound.
(These Heils had no bass of their own)
(Moved from AK New Format thread since the post has nothing to do with the AK forum software)
Are those terminals a modification, or did Heil change them from the awful little red button versions at some point?
I have two pairs, both with the red press-button terminals.
Also curious as to how you mounted those? I've been toying with different ideas for mounting them without the bolts going into the cabinet they are sitting on.
Mine currently just rest on top of the main speakers, sans bolts.
I've always been intrigued by those. Did you use them as replacements for original drivers or were they integrated into the design? And where are you crossing them over?
Picture shows an ESS Heil Transducer mounted on a Plexiglass plate I got from AK member @toddalin a few years backNope.
I want to incorporate just the heils as additional front speakers.ess heils can i just them alone in a new cabinet with a xover and use them as additional front speakers
I would just like to add them as additional front speakers, just need them for 2k and up but not sure how to do etc etcYou can't use them as a full range speaker. I had assumed you understood that, based on the mention of a crossover in the thread title.
I have a pair of Paradigm studio 60 v4 as main front speakers now , they are bi amped to my Denon Avr 2807 using the rear surround channel and are working fine. I washoping somehow to add the heils as additional front speakers somehow, it how etc?
I just purchased but not connected SVS 3000 micro sub, please advise
Certainly can be on an SACD, DVD-Audio, or Blu-Ray audio.The rear channels have different content than the fronts; they are nowhere close to a full range signal.
In re-reading your posts, I see you said that you're bi-amping your mains with the rear-channel outputs (and assumedly the front channel outputs). I don't know much about AVRs, but this doesn't make sense to me. The rear channels have different content than the fronts; they are nowhere close to a full range signal.
I have an older 7.1 system setup with my Integra Surround Preamp/processor, discrete power amps and quality speakers.
I have a number of discs with full range sound on side, rear and center channels, as well as front mains.
If you do not have full range sound on all of your channels, you are not using a properly working Surround sound system.
