Ess Seven left speaker not working
3eyedmusic
I recently bought a pair of ess 7 speakers and the right one is working, but the left one only the tweeter is playing some sound. I would like to see if it's an easy fix, or if maybe the woofer is blown out.
I tried a new fuse and tried switching the cables that worked for the other speaker but still the same result.
If more pictures are needed i can take more. I am not very experienced with speakers so any help would be much appreciated. These look and (the one at least) sounds very cool.
Disconnect the woofer in the bad speaker, taking note of which wire is connected to positive and which to negative. Using an ohm or multimeter selected to read resistance, attach one lead to positive, one to negative of the woofer. You should get a reading of around 6 ohms. If the meter reads zero, you've got a dead woofer.
