. The passive doesn't sound good with most of my amps. It sounds great with one of them. .
I think I've heard that particular setup, and it does sound pretty nice.
I've read a number of times where people say passive pres suck the life out. Often wonder if that's really true, or if it's one of those illusion-type of things.
Certainly there could be some placebo effect, for lack of better terms, if one has to turn the volume knob to the 3 o'clock position with a passive, to get the same volume that may have been attained at 10 o'clock position with a preamp having gain.
You make no sense whatsoever. Perhaps you meant terms other than dynamic compression and power compression? They do not mean what I think you think they mean...
In my experience, which is best - no preamp, passive controller, preamp - is system dependent. A couple of things that haven't been mentioned here: amps differ a great deal in sensitivity and in input impedance, and cable length will matter more with a passive controller than with a good preamp. Also, truly silent preamps are not nearly as common as they ought to be. Finally, I guess we're talking about line-level sources such as CD - not much in this thread yet about phono sections. In short, to me it is more complex than "the preamp should get out of the way."
Forget reading.
Sorry, I have to start somewhere, and I thought that's sorta what forums and such were for.
Forget reading. Set it up on the best system you can put together. Do it with the equipment of 2 or 3 friends on an audio night, if that's what it takes. If the rest of your system is not suffering from a lot of dynamic compression, you can hear the difference between amps, speakers, and switching out preamps, all in terms of dynamics.
Other than my horn-loaded system (the he-man rig), I like to listen to JBL 2226 in a 4ft cab. Spec sheet shows it has power compression of 0.7db at 60w. Maybe that doesn't sound so great, but remember this is a 97db/1w/1m driver, so 60w is a LOT of decibels, and 0.7 is not a lot. (I never get close to 60w, though the driver is rated for 600w.) For your amp to keep up (avoid compressing) it will need an overbuilt well-engineered power supply (not just a lot of watts). That rules out a lot of amps.
Get a decent CD player and try it. You want to compare a special preamp to a passive/nothing -- preferably low-gain linear low-distortion octal tubes like 6SN7. If you can get your hands on an autoformer for comparison, so much the better. Tell us what you find.
Tubino is right. Insufficiant gain control with a passive. That's why preamps exist. Tone controls are nice, but they add distortio to the signal path. You need a preamp because you need the gain. Poor gain control equals limp weenie sized sound.
The best passive pre-amp I have used is an Electra Print PVA. It uses a nickle core step up transformer in the design, so its not a true passive. However, it does a great job, and isnt too expensive to build.
However, there are several functions of a pre-amp, and a system may or may not do well with a passive unit.
1. Impedance matching between the source, and amplifier.
2. Does the source really have enough mmmph to drive the amp PROPERLY?
Op amps arent the most robust of output devices. Also the amp input sensitivity plays a factor in this. As a side note passive pre-amps can be affectd by interconnect impedance, or long cable runs.
3. Finally, the effect of the volume pot does become an issue. A standard pot varies in impedance as the position changes. Stepped attenuators do not, but thats a more expensive solution.
Regards
Mister Pig
