Explain muting relay circuit in C-4
GasMan
I recently bought a C-4 "fixer upper" and can't seem to get it to close the muting relays. Before I undertook this task I got an original printed service manual and frankly would be totally lost without it. Basically, TR-621 doesn't come up to -12 volts on the collector. Only makes it to -6. Everything going to the four transistors that are in this circuit seems OK (if you consider -19v where the schematic says -12 OK). Any magic hints? I've gone blind checking solder connections and cleaning up the Deoxit it was bathed in. Before I sign out...I replaced the lamps and they work fine. Got 14v, 80mA with 10" leads from Ken's Electronic Supply in Kalamazoo for $1.96 ea. Look like Yamaha parts. Thanks!
PM sent..Replace the e-caps and diodes including the zeners in the relay driver circuit.For D318 use two 1N4148's in series.When you get this pre squared away it should sound great.
Replaced the caps and zeners in the muting circuit and now this thing sings! What they say about the C-4 is absolutely correct! Thanks to Dave for his sage advice!
Good job..!:music: I too have bought bulbs and belts at Ken's. Also AK'r here on AK -- dgwojo is the man to see about lamps.:yes:
Don't forget the 2sc458's at TR511, TR512, TR513, & TR514 ...
And TR619-622 in the headphone amp..2SC458's are know trouble makers that frequently get real noisy .Replace with KSC1845's.
