dilettante
Well-Known Member
I tried researching this question myself and I hope someone knows the answer. I'm doing my own pc music server and am perplexed. Thanks for reading on.
I have a mini-ITX mobo to go in an appropriate streacom case with a low TDP cpu. In every other respect the mobo has all the things I want with no things I don't want.
But the mobo requires an external dc power source to the rear I/O panel and it's not a barrel socket but rather a 4-pin mini din socket.
Now, I have some limited experience concerning 4-wire dc power *sources." In the cases I know about, there are two pairs of hot and neutral wires. One pair is actually supplying the dc power to the power-eating device; but the other pair is monitoring power draw at the power-eating device to quickly compensate for fluctuations in the power consumption. I have four Acopian LPSs that have 4 power terminals, one pair for supply and one pair for this monitoring.
In past situations I found that when my power supply has this feature, I can still run a quad power cable from the power supply's four terminals (remember, 2 pairs of hot and neutral) to a 2-conductor plug like a barrel connector without that causing any problem. But this has always been in cases where the power-eating device only seems to "want" a two-conductor feed (as with a barrel socket on a motherboard or laptop).
In my current situation, though, the power-eating device actually has a 4-condutor socket (for a 4-pin mini din plug). I don't know what to make of this and is frequently the case, the website of the mobo maker is no help at all. I don't want to fry the mobo. Suppose I have a linear dc power supply with only two outputs (rather than the four on those Acopians I mentioned earlier) and I just connect the one hot conductor to the mobo's two hot inputs (and the one neutral conductor to the mobo's two neutral inputs). Does anyone know whether this is a huge mistake that will convert my mobo into an interesting paperweight?
Thanks for your thoughts!
