External FM Antenna Options for Vintage Receiver
PMCA88
All,
I have just purchased a Setton RS220, vintage receiver. It seems to be in excellent cosmetic and working condition. The only issue which I have found thus far is that the FM reception is awful. As such I would like to augment the receiver with an indoor external antenna. Ideally it would be an antenna which I don’t need to plug into the mains and which I can hide away.
For those of you unfamiliar with the Setton RS220, there is some more info to be found at the following location:
http://www.hifi-studio.de/hifi-klassiker/Setton/Setton_RS220/RS220.htm
Also please see attached some pics of the rear of the receiver.
I am pretty clueless about audio systems, although I am beginning to learn a little, with input from good people like yourselves. I have several specific questions which perhaps you could help me with:
1) I assume that on the Setton (as seen in the images) the terminals to which one can connect an external antenna are screw type terminals and if so they take either spade/ring connectors to connect to an external antenna. Is this assumption correct? Specifically does my receiver need a spade/ring type connector on any external antenna?
2)For FM there appears to be two different types of external antenna option, a 75ohm and a 300ohm. What is the difference between the two? Which option should I take?
3)For the two options of external antenna described above there appears to be a different way to connect the external antenna. For the 300ohm option it seems that two wires should be connected to the receiver. Is this correct? However I am less clear on what to do for the 75ohm setup, is there only one wire for this option?
4)There is a ground terminal, do I need to connect anything to this, or is that just for an AM antenna?
5)What is the best type of external antenna for my needs? I will want to buy the antenna on eBay, do you have any suggestions? I found a few options (I am very much open to other options though):
http://www.ebay.co.uk/itm/FM-Dipole-Indoor-Antenna-HD-Radio-SPADE-TERMINALS-Connector-RIBBON-AERIAL-/321949021634?hash=item4af5a835c2:g:TAsAAOSwAYtWLkr7
http://www.ebay.co.uk/itm/Indoor-Digitaal-TV-Antenna-VHF-UHF-TV-Freeview-Digital-Telescopic-FM-Radio-/201506336762?hash=item2eeab6affa:g:9a4AAOSwfZ1WbhWV
http://www.ebay.co.uk/itm/Indoor-Portable-HD-TV-Aerial-With-Telescopic-Antenna-FM-VFH-/181982136666?hash=item2a5efb095a:g:QzAAAOSwKrxUZZ2o
http://www.ebay.co.uk/itm/Active-Indoor-Loop-TV-Antenna-50dB-Black-Superior-UHF-VHF-TV-and-FM-DAB-RADIO-/121870745948?hash=item1c6010015c:g:5U4AAOSwGotWn7pB
http://www.ebay.com/itm/NEW-GENUINE-SONY-1-754-399-11-ANTENNA-LOOP-175439911-AM-FM-OEM-/191678033273
6)Some of the options I have listed above don’t take the spade/ring connectors, for example one has a coaxial connector. Would it be possible/suitable to use an adaptor, for example the one below:
http://www.ebay.com/itm/UHF-VHF-FM-Gold-Plated-75-300-Ohm-TV-Coaxial-Antenna-Cable-Matching-Transformer-/252189063331
Many thanks for your time and advice,
Peter
