specialidiot
Break Glass, Smoke Lucky
After building Gary's (ejfud) F5 monoblocks using Toshiba actives, HEXFRED rectifiers, and boutique resistors, it was just a matter of time before I'd build new boards for my F5. With all of my more pressing audio projects out of the way, I set to stuffing a pair of cviller boards.
I'm using Takman carbon composition resistors in most places. The 3 watters are Panasonic, and the 10K is a Vishay which is simply used as a current limiter for the power indicator LED.
Next step is to install the active components. I've learned my lesson to take my time and quadruple check that I have the proper devices in the proper location with proper orientation. Don't ask why.
Here are the two boards with the resistors installed. Not what I've done with the leads of the .47 ohm 3 watts - these are the resistors we measure for bias current. I won't have any problems getting my meter leads to grab.
