I recently picked up a pair of FaitalPRO HMF200 2-inch midrange compression drivers after Al at US Speaker recommended that I give them a try.
My first impression is pretty simple: this is an incredibly smooth driver. I was particularly interested in the HMF200 because of its unusual paper diaphragm and its ability to operate considerably lower than most conventional 2-inch compression drivers.
The HMF200 uses a 1.46-inch (37 mm) voice coil, double-edge paper cone diaphragm, annular phase plug and neodymium ring magnet structure. It has a 2-inch exit, 108 dB sensitivity and weighs only 3.6 pounds. FaitalPRO specifies a frequency range of 450 Hz–9 kHz and a minimum crossover frequency of 450 Hz with a 12 dB/octave or steeper high-pass filter.
The paper diaphragm was one of the things that caught my attention. After listening and measuring it, I can say that so far I really like what I'm hearing. It has a very smooth, natural presentation, and the measurements I've taken so far reflect that smoothness as well.
The low-frequency capability is probably the most interesting part for the Klipsch crowd. My testing so far suggests that the HMF200 is comfortable operating down around 400 Hz on a properly sized horn. That's below FaitalPRO's published 450 Hz minimum crossover recommendation, so I'm treating 400 Hz as my test result, not a manufacturer recommendation.
That makes it particularly interesting to me for use with the ALK CSW-450 crossover, which I'm currently preparing for testing. A driver specifically designed to operate this low, combined with the smooth response I'm seeing, makes the HMF200 a very interesting candidate for Heritage-type applications where the horn is large enough to properly load it.
For reference, FaitalPRO rates the driver at 40 watts AES / 80 watts maximum, with a 2.1 T flux density. Unlike many conventional HF compression drivers, this really is designed as a dedicated midrange compression driver rather than simply trying to force a high-frequency driver farther down than it wants to go.
FaitalPRO HMF200 at US Speaker
The comparison here is between the FaitalPRO HMF200 and the PRV Audio D2200PH simply because these are the two drivers I currently have available to test side by side. I'm not really approaching this as a question of which driver is "better," because I think their strengths lend themselves to somewhat different applications.
So far, the HMF200 appears to be the smoother of the two, particularly when looking at the response across its operating range, and its low-frequency capability makes it especially interesting for applications requiring a 400–450 Hz crossover. The PRV D2200PH, on the other hand, remains an impressive budget driver and offers a tremendous amount of performance for the money.
To me, the more useful comparison is where each driver makes the most sense, rather than trying to declare an overall winner.
