Fake NEC Transistors?
promitheas73
Hello everyone
I own an old Marantz PM710 DC and the power transistors of one channel are off. The transistors are the following:
2SC2588A & 2SA1108A.
These are very difficult to find as you already know, but after a lot of search i found an AliExpress supplier who seemed to sell original NOS NEC transistors. So the obvious question, are these original of fake?? Anyone who has the experience (especially for the specific transistrors) may help.
What i 've done so far:
1. Drop voltage between B/C, B/E seems ok for all of the transistors (0,510 ~ 0.530 V)
2. hFE varies from 80 to 210 (don't know what is that number exactly but compared to my original working pair seems ok cause i get hFE of 50 for the old original pair)
3. Checked NEC logo vs my old pair doesn't seem the same. Also the color and the texture of the plastic case doesn't seem the same.
4. The outer case of the old ones is much shiner (better polished) than the questioned ones.
5. The batch code number (the last line on the trans itself) is the same for all the 2SC2588A's & the same for all the 2SA1108A's. Is this supposed to be the case?? My original old pairs have different batch code numbers so i think this is a very strong evidence that these are fake trans (correct me if i am wrong).
Pls consider that i am not an electronics expert. I ve made all my measurements with a multimeter which is the only electronic gear i have.
Thanks to all in advance & pls check my photos.
If you bought a set of new transistors from Digikey say 4 each 2SA1494 Sankens they would all most likely have the same batch code. Your batch code theory doesn't hold water..
Check if presumed counterfeit print is removable with acetone and check C-E capacitance of said device compared to original, as this is a fairly linear approximation of the surface area of the silicon.
Any transistors from China are fake
Get these subs from Bdent
2SA1108 / 2SA1295
https://www.bdent.com/2sa1295-sanken-audio-power-transistor.html
and a 2SC2588 / 2SC3264
https://www.bdent.com/2sc3264-sanken-audio-power-transistor.html
If i use this pair do i have to replace anything else in my amp, or its a straightforward replacement? Also these trans have different hFE from the originals, does this mean anything at all?
Since one of the trans is out of stock, i ve checked local market (Greece) and i ve found them. Is there a chance that these trans would be a China import so probably fake too?
Also Sankes are available at ebay, fake again??
Thx
I followed this post (https://www.audiokarma.org/forums/i...lar-junction-transistor-testing-basics.43186/) for checking the new trans and everything is ok also compared with my original old pair. C-E capacitance is the same as original for all the new ones. I ve tried acetone, alcohol, brake cleaner, the logo is still there. Either these are a heck of counterfeits or they are good working pairs! The only inconsistency in measurements are the hFE readings. I get 170, 212, 179, 154 for the pnp's (old original 82) and 35,59,54,110 for the npn's (old original 83) which is rather strange readings.
Is there a way to apply load (voltage perhaps) with a computer PSU and a very basic schematic and make some checks with my multimeter?
Thx
