Falcon LS3/5A B110 Drop-in Replacements?
:thmbsp:Thanks! I'm happy to hear that!
Make sure you let Falcon know what you intend to use them for, the driver may need some modification to meet the specs of the original (for example, my IMFs B110s have a coating on the cone. I don't know if the B110s on the LS3/5a have had any similar treatment).
Sent from my iPhone using Tapatalk
The coating on the cone is Plastiflex. Plastiflex was used on all Bextrene cones to dampen the resonance which is inherit in all Bextrene cones.
Plastiflex has also been used to dampen paper cones, hence the term a doped paper cone.
Nice information! I knew the cones were Bextrene, but i wasn't sure about the coating material. Mr KEF Cantatas use B110 also, but with a different model number (not SP 1003). I was curious if that made a difference also.
