I thought there were 5 or so iterations that were lettered and then a couple of those had suffix numbers similar to the SP-3, SP-3A, SP-3A-1, then the later version the SP-3B and the rebuilt by Audio Research early versions called the SP-3C. I think there are way more than 4 versions of the SP-6, enough to keep me confused.I just recently purchased my third (yes, I have 3) SP-6. As you can probably tell--I like them
One big thing to watch for with ARC gear are the various "iterations" within a given model. IIRC, there are 4 different iterations of the SP-6--Mark I, II, III, IV. Certain iterations within a given model run are more desireable than others for various reasons.
Correct. I believe the correct answer is nine. Click here for the evolution:I thought there were 5 or so iterations that were lettered and then a couple of those had suffix numbers similar to the SP-3, SP-3A, SP-3A-1,
As Jim indicated "LS" stands for "line stage". Those with phono stages have a "SP" prefix. I sure love my SP20 mated with a DAC8.That said my favorite is the LS-22... It has a good phono stage.
Wow - looks like I have plenty of reading to do. Thanks for all the replies!
I’m OK with either a line stage or one with phono pre built in, but was really thinking about something like SP-8 or SP-10 vintage - one with a built in phono.
Not sure that my wallet will step up to most of the newer ARC products so something “vintage” should suit me well.
With my large PC based monitor, I see just a slightly smaller image.Gave this a little fix.
Since I take pics with an iPhone, I struggle with rotation. When I link from my webspace, it might look fine using a computer, but not a phone/pad. Or vice versa.
