If you've been to snowy places you've seen the cables strung horizontally along metal roofs to prevent sudden mass unloading of snow. They also use cleats. I need a similar thing for my shop building. It's 35x85 so a lot of roof to cover. I figured out a cheap solution: 100' rolls of stainless steel braided cable from Harbor Freight. But how to fasten it an inch or two above the roof while preventing leaks around the fasteners?
I thought of using a screw eye into the wood truss. The special screws used to hold the sheet metal on are a hex head with a built-in rubber washer with a metal washer over it. When you screw it in, the rubber washer seals the penetration.
I could use an eye bolt, rubber and metal washers, and a nut to tighten it all against the sheet metal, but an eye bolt has the wrong threads for wood. If I used a screw eye with wood screw threads, there's no thread to put a nut on to compress the rubber washer.
I wonder if a dab of silicone caulk is enough to seal up these penetrations. I don't want to create leaks in my roof, I got enough problems already with the snow. Including a destroyed gutter and a broken window (from a mass unloading of 15" a couple years ago).
Thoughts?
Thoughts?
