Hi Everyone,
I have a Marantz PM400 that I have been repairing/restoring. Currently I have an issue with one channel having lower power output than the other. It also sounds a little dead or muffled when compared to the other.
I'm looking for advice on where to check next. Should I start with checking transistors, capacitors or resistors? below is a list of what has already been done:
Thanks
- Electrolytic caps replaced with new (ceramics are still original)
- Power transistors replaced with modern SANKEN equivalents
- Looks like some of the pre-amp transistors have been replaced, suspicious they may be fakes
- some resistors have been replaced but look like good quality (mostly - there are about 3 cheapos in random places)
- tested with different speakers to make sure it was the amp
- tested with signal generator and CRO and one channel is definitely (but very slightly) lower output.
- Checked the bias voltages and they are all pretty good in the pre-amp. A little high in parts of the power amp. The main +- rails should be +-36V but they are 40V even though the AC supply is spot on.
- Check output transistor idling current. Its very touchy and susceptible to temperature. Blowing on the power amp causes bias to drop 20% almost instantly. Is this normal?
Thanks
