Faulty Cartridge?
Geigartt
History: After 30 or 40 years I am re establishing my relationship with an old system. I had my vintage Dual 1219 refurbished 2 yrs ago. I was admittedly lax about what exactly was done. I don't think anything mechanical other than lubrication, new belt, power cord and phono leads were added. It cost about $250. I "tested" it to the extent that I played half dozen of my old albums. A new Shure N97xE was installed. It is also marked "M97 x" on the side of the cart. The dissimilar numbers says something (negative?), but I do not know what, about Shure.
Recently I purchased some second hand albums, one vendor does nothing in the way of cleaning of the vinyl; a second vendor is much more hands on and ultrasonically cleans about half of what he sells.
The problem: (I can't say when exactly I first noticed this. but I now get "pops" and skips/slips (it jumps forward or sticks in the same groove and repeats). I noticed if initially on an album that was ultrasonically cleaned. It happens on almost every cut, rendering the vinyl pretty much as trash; also on other new vinyl and also on some of my 70s era, which I take very good care of. And accessed very infrequently over the 50 some years they have been in my collection. The tone arm was set to 1.25 grams, anti-skate at zero. I increased the weight to 1.75 gr with some improvement, but overlall, still pretty useless. There are no obvious scratches on the new or old vinyl, but I don't know what that proves as it depends solely on my old eyes. If I mute the speakers and put my ear close to the cart, I can hear a lot of grinding and swoosh emanating from the stylus itself. It does not follow the sound track, i.e., it does not sound like music, but does sound like it is produced by the stylus physically contacting the groove.
Other than this $250, I haven't invested anything in my system over the past 50 years, which is comprised of a Sony home entertainment receiver and a Bose Series 5 bookshelf speakers and its subwoofer. Nothing remarkable about this system, I admit. I should put all but the speakers on the sidewalk and start over, that would be too easy; I would like to understand what is happening before I chuck it. I appreciate any suggestions.
First, you don't mention anything about having cleaned the stylus, sounds very like it's gunked up.
Also, how are you setting/confirming the VTF (vertical tracking force)?
A few tools I suggest investing in if you don't already have them, all in $25 - $30.
digital stylus scale
stylus alignment protractor
jewellers loupe similar to this
And I've been using this to keep my stylus clean for decades, about $13.
"I "tested" it to the extent that I played half dozen of my old albums. A new Shure N97xE was installed."
It's very possible he received a defective stylus, he wouldn't be the first.
Shure quality control got dicey late in their production life. And I've had a few defectives myself in that era. Jico is much more consistent today. I agree with what you're thinking.
OP is responding: Thanks to all for suggestions, plenty for me to do here before replacing the stylus which I am sure is at least 50% of the problem.
If it's a n97xe w/brush tracking should be set at 1 3/4-2 grams to operate properly. The action of the brush negates 1/2 gram of the downforce. Some aftermarket stylus only subtract 1/4 gram. Set tracking force with the brush in the up position then put it down or leave the brush up at 1 1/4-1 1/2 grams.
Care package arrived yesterday. Also found a 10x loup in basement. Couldn't see anything on the stylus, but cleaned the stylus and cart. contacts to arm and re-set the alignment of cart. with new protractor (May Records). Problem(s) solved. Thanks all!
I'm afraid it was a Premature happy ending, [better than no happy ending, I guess]. Skipping is back, also happens on one of my circa '70s record of NY Rock Ensemble: to recap, stylus has been cleaned, scale says force is 1.98 gr, anti-skate is set to hold steady tracking, i.e, no movement on the Shure Obstacle Course record. I just rec'd my Vevor ultrasonic cleaning machine. I need to get the proper cleaning solution concocted and I will report back. A knowledgeable friend suspects the problem might be something in the tone arm binding; I can't feel anything, but "feel" is not measurable; I don't think there is anything else I can do to the 1219 other than change the cart/stylus? It was refurbished a couple years ago.
I was also wondering about the arm sticking. I do not know Duals at all, but I've had this happen on other things when the arm was binding up for whatever reason.
