Faulty tube, which one to replace, there are so many?
i have some old ones in service as well, but I would not sell a unit as "restored" with old ones in it. At an absolute minimum, they would get a full checkup to verify if they are operating in spec for value and leakage. I'm also keenly aware that just because its working today doesn't mean it will keep going.
I agree, I certainly would not call it restored with 50 y.o. power filter caps. Sure, some will 'reform' but they're potential to fail will always be there. Plus, with a completely rebuilt power supply it just sounds and plays so much better.
If it's acting up in both channels, pull and test V14 and V15 before digging under hood.
Unless you're spinning vinyl, pull V16 and V17 - needless waste of two good tubes and unnecessary added load on the bias supply.
Good luck.
I swapped the tubes from the V16 & V17 slots into the V14 & V15 to see if they were at fault, but it didn't change anything.
I also DeOxit the AUX connectors in the back.
Is there a recommended tech that everyone here recommends to repair Fisher 500c?
I remember hearing that there were a few Audiokarma members who did repairs.
Where are you located (Add to profile, county and state is fine) and are you willing to ship, or need someone local to you.
