Fender Twin Reverb - Random Feedback - Troubleshoot and Repair
JRUBIN
Here we have a twin reverb on the bench, and this is a strange one. The sound, which as described sounds like a feedback condition, did not happen when presented to me for inspection on-site. and while I think I know why, I still have to observe all safety procedures.
Just in case the speaker explodes ill be using an auxiliary speaker for testing. and having found an extra set of tank cables ill be going through that too to ensure that the connections are correct as well as clean, just to rule anything there out.
Firing up the amp I notice that the bias has drifted on the final since last inspection. That is to say, they have gone further out of balance since last time, with a delta of 6mA. These are all original tubes for an amp that sits on most of the day, probably time for a swap.
I also check some of the higher wattage resistors under the finals as well. Using a plastic tweaker I touch through components to listen for noise on the output, I identify a very microphonic 12ax7 in the preamp stage. I hit all the sockets with De-oxit and clean them. Immediately after I found all of the pots to also be crunchy and had to clean all of them too. The combination of the pots and the microphonic tube on a hanging cable in a small room could have easily caused the feedback condition if it caught in oscillation.
The owner decided that the original tubes would go on a bookshelf and all tubes would be replaced. All of the new tubes were tested on the Hickok and were shown to be good. The matched quad set was a good march and the amp was biased to 31mA.
Rotate the microphonic 12AX7 with a known good 12AX7. See if that solves some of the noise issues. Which I guess is what you did, by replacing all tubes.
New output tubes (6L6GC) will drift around, for about the first 15-30 hours. The bias should settle down, after that. If not, you may need to tighten the tube socket tangs. Be careful, as tube amps can hold quite a bit of voltage, for quite awhile after being turned off. I usually drain the main caps & have amp unplugged --- before playing with sockets and any HV areas of the amp.
Good luck! :thumbsup:
Pretty cold bias . If i guess the plate voltage around 450vdc . Even if the plate voltage is 500v .
Probably a microphonic preamp tube or sometimes the reverb tank ( should be in the bag).
Agree on the bias- I'd expect that to be more like 40ma or so per tube. At even 500v, that's 20 watts of dissipation on a 30 watt tube. At 450v, it's only 18 watts dissipation. That's about 60% or so of max dissipation- probably about the sweet spot.
It's also possible for a cap to microphonic- so if changing tubes doesn't fix that, it would be a good idea to "tapping test" the caps in the early gain stages in the amp.
Regards,
Gordon.
Regards,
Gordon.
Yup! Use a WOODEN chopsticks and carefully tap the components and see if you can elicit the noise.
I have a unique situation here, given the line voltage as 'rather high' for this daily use unit, i told them all of the original tubes should come out. Until a bucking transformer is fabricated into a box for the mains to be plugged into, I biased it down on my bench. The voltages in actuality, and current, will be higher in its actual location.
