Thought I'd follow up after doing some testing/measuring of my FR1 MK3F in three different arms. The sticks were a Technics 1200 with KAB damping, a jelco 750L and a Fidelity Research 64S. Knowing that the Japanese typically rate their compliance at 100 Hz the FR should be higher at 10 Hz. It appears my sample is in the range of 14.5-16. I used the resonance calculators at vinyl engine to come up with the estimate. Hopefully that will be helpful to others.
With that guesstimate groovetube your Technics 1400 arm is fine for the resonance range results. When I had it in the 1200 it was fine too around 8 Hz with a higher than stock weight headshell.
As an aside plotting the resonance result of the FR1 MK3F was interesting. I found it quite different than other carts I've tested, in that the audible warble using the test record, (HiFi News latest version) doesn't produce a noticeable amplitude peak in the graphs. All three arms have a very similar plot almost a shelf rather than tall peak. These FR carts must have some serious internal damping. Curious...
Blue Shadow isn't your avatar pic an FR arm?
